DRL + accessory lights
I have 2001 4Runner SR5 which came equipped with Daytime Running Lights (DRL).
When it gets dark outside, my DRL automatically switch to regular low beam lights, which is perfect. But unfortunately my accessory lights, such as gauges and instrumental panel do not turn on. i have '98 Chevy Monte Carlo and there everything would turn on at once because of the DRL. Does anyone know if it is possible to make DRL control accessory lights? And if so, which wires do I need to connect or disconnect from DRL relay? Thank you in advance, -- Andrey |
Wouldn't doing that make it like just turning on your lights?
