double treaded studs?
Old May 22, 2004 | 11:53 AM
RufusRunner's Avatar
Right now im replacing my stock clutch fan w/ a metal flex fan, but heres the problem I ran into, I needed to replace the four bolts that hold on the pulley for the water pump, and I found out there not bolts, there studs w/ tread on both sides...Anyone know how to get these off? heres a pic, any help would be awesome, thanks
Old May 22, 2004 | 12:01 PM
bike4miles's Avatar
Yea man, it's easy. Just take two nuts that thread onto the stud, lock them together on a single stund, and then they surve a bolt head to unscrew the stud. It works like a charm. If they come loose, just lock em together harder.
Old May 22, 2004 | 12:02 PM
sounds like a plan, I'll see what I can do.
Old May 22, 2004 | 12:11 PM
bike4miles's Avatar
Yea, just use the lower of the two bolts when you try to unscrew the stud and the nuts will be less likely to come loose.
kawazx636
Oct 6, 2021 03:03 PM
Swampwalker
Oct 12, 2015 09:49 AM
Ilovemountains
Sep 15, 2015 04:17 AM
chuckd83
Sep 14, 2015 03:20 PM
