Does 3.4L V-6 have timing gears, or chain?
Does the 2000 4Runner’s 3.4L V-6 have timing gears, like FZJ80’s 4.5L inline 6, or does it have timing chain or belt?
If chain or belt, what is interval to replace it? |
belt and im pretty sure its 90k
when i worked in the repair industry we always said do it at 80k on everything just to be safe.....
and the 3.4l toyota v6 has a timing belt |
How To Tell
Usually the way to tell if you have a timing belt or a timing chain is by the cover. If it has a chain it has a metal cover and if it has a belt it will have a plastic cover.
The 3.4l is a non interfearence type engine. You dont really HAVE to change the belt. If it breaks, just center the cams and crank with a new belt.
Of course being stuck on the side of the road because you were too cheap to change out a $30 belt would suck! |
