difference between 4.10s and 4.88s with 33s
Old Apr 19, 2004 | 09:41 PM
Brendan's Avatar
is it worth the money and labour? i don't have any on-road complaints with my 4.10 setup except when i climb hills
Old Apr 19, 2004 | 10:08 PM
Glenn's Avatar
Having gone through a regear, I think that it is worth the money.
I can't tell from the picture...what engine do you have?
Old Apr 19, 2004 | 10:32 PM
AgRunner06's Avatar
How much does a regear usually run after parts and labor (breakdown please)?
Someone correct me if I'm wrong, but I think this is something that not your average shadetree mechanic can undertake. That's just too bad.
Old Apr 20, 2004 | 12:02 AM
superjoe83's Avatar
Talking
I still have the 4.10's in my taco with 33's and its not too bad, if i do regear i will go with 4.56's, that will put my power close to stock, 4.88's are a little low for me, as for setting up a ring and pinion, it just takes experience, and to know what to look for with the tooth contact patch, or pattern. when i was at UTI and in Truck Powertrains, we set up 3rd members out if class 8 trucks, it actually was easier than you would think, but i wouldn't recommend anyone to try to set up their own, its not worth it, you will save x amount in labor, but when you eat up a set of gears, then you will regret it, and it will cost you more in the long run
Old Apr 20, 2004 | 01:34 AM
jimbo74's Avatar
4.88s is probably going to be too much gear for 33s.... 4.56s or even keeping the 4.10s would be more appropriate
labor and gear will most likely run about $400 per axle
Old Apr 20, 2004 | 06:02 AM
JadeRunner's Avatar
I agree, stick with the 4.10 toy gears. Unless crawling is the priority for you. I would not like the higher rpms at highway speeds with 4.88's. That's a show stopper for me. I hear 1800.00 for gears and labor installed, if you do the diffs. 2400.00 for a crawler, installed which is what I'm saving for.
Old Apr 20, 2004 | 06:08 AM
shazaam's Avatar
I'm getting 4.88 this weekend. And the suggestion of this board was 4.88 if your s/c or plan on crawling or both. Gas milage is going to suck .. but oh well, its only an extra $1 or so every fill up, and you get a better off road performance
Old Apr 20, 2004 | 07:20 AM
RTdawgs's Avatar
you guys are failing to note that he has a 1992 truck. 4.88s will be great. in fact, it was a factory option for some 4Runners with 31s.
Old Apr 20, 2004 | 07:41 AM
JadeRunner's Avatar
Yup, good catch. We stand corrected. Go for it!
Scott
Old Apr 20, 2004 | 07:43 AM
Churnd's Avatar
Yep... I'd go with 4.88's. I've got 4.56's factory with my 31's right now, and it's a perfect match. Some even go as low as 5.29's with 33's, but that's those who use their rig most off-road. 4.88's will bring your performance closest to stock, but slightly better.
Old Apr 20, 2004 | 08:09 AM
Brendan's Avatar
22re. there's a local guy thats selling front and rears for $450 cdn. i'm thinking about doing the deal. a bit more power up the hills would be great, but higher rpms on the highways is not what i'm after. it's too bad i couldn't find someone else that has the 4.88/33 setup and take their truck for a test drive.
Old Apr 20, 2004 | 08:40 AM
RTdawgs's Avatar
wow, the 22re huh? i cant imagine the 22re with 4.10s and 33s, i dont like my 3.4V6 with 4.10s and 33s.
i would cash in on that local deal for 4.88s and come back and tell us how much you like it.
Old Apr 20, 2004 | 08:47 AM
kyle_22r's Avatar
actually, guys that are really serious about crawling/etc will use higher gears, like 4.10s. stronger ring and pinion. they just make up for it with more transfer cases
lower diff gears helps quite a bit on the road. generally the rule of thumb for 4 cylinder minitrucks is 4.56 for 31, 4.88 for 33, and 5.29 for 35, with manual transmissions anyhow. don't taco 4 bangers have much higher gears stock, like 3.58? then i could see using 4.56s for 33s
i'm probably gonna stick with my stock gears for a while, i'll probably wait until i have a 5 speed to regear(higher diff gears are much nicer with the 4 speed, since there's no overdrive)
Old Apr 20, 2004 | 11:53 AM
superjoe83's Avatar
my '99 has 4.10's stock, according to the door sticker code
Old Apr 20, 2004 | 11:54 AM
Flygtenstein's Avatar
So right now you have 33's, you have 4.10's and you have a 4 cylinder? You do not, however, have any issues with this set-up? I think it sounds to me like you ought to stay where you are at unless you are regearing.
Just parts for a regear, and only a regear, is $800 if you go with good gears, new bearings, etc. You are looking at another $200 or so per diff if you drop off the diffs and much more if you drive in and drop the whole truck.
I have around $2500 into front and rear ARB's and 5.29 Precisions. I could not deal with 4.56's and 31's let alone 33's.
If you have no issues and are not putting in lockers, "Leave the bloody thing alone."
Old Apr 20, 2004 | 03:51 PM
anthony1's Avatar
If you want to maximize the power your 4banger puts out then regearing with 4.88 is a good way to go. You'll be surprise. Right now, compare to stock, you're driving uphill all the time....
I have V6. I could tell the differece with 4.56 with 33's and 5.29 with 35's. I feel like my truck hae more horses than before.
Old Apr 20, 2004 | 04:55 PM
Brendan's Avatar
ya, it's just the hills that bother me. like i said earlier, there's a guy selling front and rear 4.88s (V6 rears) for $450 cdn. I could just buy them and swap em at a later date when i have more time. just wondering if this is a good deal or not. he says the truck had 160,000 kms that they were taken out of.
Old Apr 20, 2004 | 05:17 PM
SolidDigital's Avatar
I'm thinking about eventually putting a 2" lift on my truck and 33x12.5's, if/when I do that I'm gonna stick with my 4.10's
quick question, can the speedometer be corrected? I heard from someone a few years ago that you can't fix it once you move up to an even larger tire..
I think mine's about correct right now, I measured a distance in my moms car and then in my truck with the odometer the car said 5.7 miles and my truck's said 5.6...
Old Apr 20, 2004 | 05:47 PM
Arnold's Avatar
IMO, 33's and 4.88's w/ a 22RE would be perfect. Got 32's and 4.88's and my highway RPM's is a little high. As for the speedometer question, they make a speedo calibration unit that installs between the speedo cable and t-case. A speedo shop should be able to get you one. You provide 'em your gear ratio in the diffs and tire size and you'll get a unit calibrated to those specs. Got mine from Downey.
Old Apr 20, 2004 | 07:01 PM
95_4X4Runner's Avatar
I've got a 5 speed, 31's and went from 4:30 to 4:88's last week. It drives like a totally different vehicle, and I wish I wouldn't have waited for so long to do it. When these tires wear out, I'll probably go to 32's to slow it back down a bit.
As proof, I let my wife drive it this last weekend, and she could care less about the stuff, and she noticed it drove a lot better.
