YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Dash seperating? (https://www.yotatech.com/forums/f2/dash-seperating-225660/)
xcmountain80 Dec 11, 2010 09:19 AM
Dash seperating?
This has been going on for a while and while it doesn't seem to be horrible it is getting worse slowly. The dash cap looks to be separating from the frontal section that is connected to the fire wall. Can I tighten it back up to take the gap out or......
take a look and see what you think.
http://i36.photobucket.com/albums/e3...e/4a444e49.jpg
http://i36.photobucket.com/albums/e3...e/39b7cf41.jpg
A
bobby_duce Dec 11, 2010 09:37 AM
well that doesnt look too bad at all. I was curious to see what kind of solution that other people have done to fix the problem. so I searched Google and someone used this...
http://solutions.3m.com/wps/portal/3..._Weatherstrip/
im sure any adhesive would do the job. :great:
Qyota Dec 13, 2010 08:37 AM
Mine's doing the same thing. I just covered it up with a nice velour dash mat. :-)
xcmountain80 Dec 14, 2010 08:04 AM
I've never actually liked those. The adhesive would work if the dash moved but it's like a tectonic plate, it moves away slowly over time and cannot to return to where it came. I though about some sort of trim in the shape of a T made of plastic. For the contractors, something like what you place between FRP panels but w/o the catch edges for the FRP leaving you with a T. Or say to hell with it and let it be.
A
from_CO_2_AK Dec 18, 2010 12:46 PM
with my tacoma i thought id just replace the dash......that was horrible it took forever it took so much wrestling to get in yet i was very satisfied with the new dash and glove box but if i remember there are clips that hold the top part down so maybe just replace em
Yota Runner Dec 18, 2010 07:29 PM
just tint the lower part of the windshield so you cant see it anymore :D
I'm not sure what to do about that... Dang I hope mine isn't doing that...
terminator Dec 20, 2010 04:30 AM
My 4Runner had a tear just over the glove box and under the airbag. I thought of glueing a 4Runner emblem over it but found a dash at a JY. It was a PITA to remove it but once the entire dash was out you could see how to separate the padded top piece. There are multiple metal tabs that are just bent over holding the padded top to the plastic frame of the dash. Just straighten them and the padded part will separate from the rest of the dash.
It's tedious to say the least and you have a ton of wire looms connected to the dash, air ducts, etc. that you need to remember where they go. If you have the time and patience then go for it. I'm VERY happy I did it. I could have just bought the entire dash but $ was tight so I opted to just buy what I needed plus it was a good learning experience.
