Cross Drilled Rotors
does any one run Cross Drilled Rotors?
if so do you like them? I am thinking about getting a pair of sp's for 200.00 thanks |
I got irotors from www.irotors.com recently. They seem to be doing real well. Only $149 a pair for cross-drilled and slotted rotors!
Chris |
i just put slotted rotors from power slot on my t-100 and so far everything is great .
airrikk17 |
thanks for the info. I definatly need them with the extra power..
What vehicle are you driving, because irotors.com has them for the 4runners for sure, because I just bought them. I'm sorry, I assumed that's what you were driving. The site is pretty well laid out, so if you didn't see them for your vehicle, I'd assume they don't make them. Sorry!
Chris |
I got ahold of ir rotors they do have them for my taco. did you get their pads also?
thanks for the info. |
Nope, I'm running the performance friction pads 4364 that you can pick up at any autozone, and they have a lifetime warranty.
Chris |
There is a group buy going on right now from Island Motorsports. I just got mine in the mail. Going to install them and the performance friction pads as soon as it stops raining down here in the rainforest known as Florida. This is from the original thread:
Brembo's for specfically for tacomas, it was $60 each, $120 per pair. and you choice of slotted,drilled,or blanks. and $20 extra to have them rust coated. just call up Island Motorsports, @ 714-522-7457 and ask for Jimmy and tell him it's the tacoma group buy. To order and they'll handle everything. For the ones with special brake orders, (SAS, and other trucks or cars) just call him up and ask him accordingly. |
thanks I will call tomarrow they are much cheaper than the irrotor
i just installed some powerslot slotted rotors myself. i considered installing some cross-drilled and slotted rotors but my friend said that there wouldnt be a lot of braking surface so i had to choose one. :bounce: :bounce:
