YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Crank bolt (https://www.yotatech.com/forums/f2/crank-bolt-302101/)
fierohink Oct 11, 2017 03:18 AM
Crank bolt
can you use the starter trick to break the crank bolt loose on a 5VZ like you do on a 22RE?
Marc Oct 11, 2017 07:30 AM
Yes you can.
You still need a holder to torque it down properly though.
aowRS Oct 11, 2017 07:56 AM
I fabricated a pulley holding tool last year in order to do the timing belt, etc. on my 4Runner. It's about 3' long and has two pins that engage holes in the crank pulley. Worked perfect to loosen & tighten the crank bolt.
You're welcome to borrow it - I'm in Ellicott City. :)
https://cimg3.ibsrv.net/gimg/www.yot...0fc1884ce7.jpg
Andreas
fierohink Oct 11, 2017 08:31 AM
Andreas
I might take you up on that!!! Shoot me a text and we can work on arrangements
412-389-1974
75w90mantraN Oct 11, 2017 08:34 AM
That is a fine tool.
aowRS Oct 23, 2017 08:00 AM
412-389-1974
Dan,
Nice to meet you today. Hopefully my bush-league welding holds up when you bring the crank bolt to torque. :)
Andreas
