coilover spacer question?
on a 2000 prerunner could tou run a coilover with a spring spacer on top for a little xtra lift and just not have the coilover cranked up all the way?
to run a top out spacer on a regular style strut you have to install longer studs to the top plate. I don't know if the 3 studs one the top of the coilover is long enough to run a spacer.
| All times are GMT -8. The time now is 10:12 AM. |
