YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Code P0505 Question ! (https://www.yotatech.com/forums/f2/code-p0505-question-142686/)
Finch Apr 13, 2008 06:19 PM
I have a 01 4runner v6, the check engine light came on code is p0505. I did a search and found idle control system malfunction. If i clean or replace iac will this fix the problem ? The check engine light went off today and did not come back on so far.
jason191918 Apr 13, 2008 07:03 PM
Just because the engine light went off, does not mean the code is gone.
http://www.ncttora.com/fsm/2000/Repa...ngine/dtcc.pdf
It is possible. Do the list here in order.
