Clutch Pedal Bushing / Spring Mod-- QUESTION??
Old Jul 28, 2005 | 08:53 PM
GoudyMan's Avatar
Just a question about the clutch bushing mod. The new spring I put in rubs agains the rod that used to hold the older coil/ spring. This creates a little noise when the clutch is pressed all the way down.
It's not too loud so do you just ignore it??
I was thinking I could file down the rod so it didnt rub.....
How do the rest of you deal with this?
Old Jul 29, 2005 | 08:02 PM
GoudyMan's Avatar
bump???????
also, the dealer wanted 197 to fix the bushings... HAHA
Old Jul 29, 2005 | 08:07 PM
Bob_98SR5's Avatar
from what it sounds like, you are not talking about the clutch bushing mod. you are talking about the spring mod. the clutch bushing mod is not really a mod. its the procedure to replace the broken clutch return spring bushing.
anyways, i did as others have done a la "unhappy99". i did away w/ the clutch bushing and replaced it with a spring. as for the little piece of metal that protrudes from the clutch pedal and holds the clutch bushing itself, i dremel'd it off. no more sound :p
bob
Old Jul 29, 2005 | 09:09 PM
GoudyMan's Avatar
yup, thats what i was wondering.
dremel time... thanks
smthwsn357
May 1, 2024 07:28 AM
glowz825
Jan 25, 2022 09:28 AM
andrewtexas123
Jul 23, 2015 11:22 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
