Climate control lights not working...
I just installed my XM radio in my 97 4Runner and now the climate control and cigarette lighter lights aren't working. I didn't wire anything in I just pulled the center console to run the antenna wire. All other lights are working and I made sure I plugged everything back in when I put back together. Is there one connetor for those lights or a single fuse?
I'm going to pull it back apart to see if I missed anything. |
Those lights are on the same fuse as the rest of the dash lights, so you must have missed a plug.
hupptoy |
That's what I thought. I'll be sure to check all connections when I pull it back apart, thanks.
| All times are GMT -8. The time now is 03:22 AM. |
