YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Check Engine Light (https://www.yotatech.com/forums/f2/check-engine-light-83692/)
adhue Apr 15, 2006 01:09 AM
Check Engine Light
Last night while I was driving home from college I went to pass a truck and the Check Engine Light came on. Does anyone have an idea what this could be?
sgirt Apr 15, 2006 06:04 AM
Take it to AutoZone and see what the code is. Mine keeps throwing the P0171 code. I have had great help from the people here. Post back with the error code.
MTL_4runner Apr 15, 2006 03:50 PM
We need a code number to be of any help to you with diagnosis.
Get the codes read and post back.
adhue Apr 17, 2006 10:37 PM
I went down to autozone and the code came up that the camshaft postion sensor was bad (I forgot to write down the actual code for you guys). I went home to see how easy it was to get to and noticed the plug hanging there. I feel like a complete dumbass but i guess it happened when I was changing the belts on my rig. I bumped and broke the camshaft position sensor connector but I got it put back together and the light went right out. Thanks for everyones help offerings anyway.
MTL_4runner Apr 18, 2006 07:28 AM
That's why OBD is so invaluable.
Glad you got that fixed!
chip Apr 20, 2006 11:22 PM
when i start my 1990 3.0 v6 pickup everything is fine no light comes oneverything is fine but then when i put it in gear though and start going the light pops on. So i shut it off again and then restart it and there's no light on, put it back in gear and start going it comes back on, I dont know what it is. It also has a pretty heafty oil leak wich im hoping its comeing from the valve cover gaskets HELP ME OUT GUYS IM SCARED FOR MY BABY
GSGALLANT Apr 21, 2006 03:39 AM
Same advice as above. Get the code read. Actually, with a 1990, you can do it yourself by shorting out a couple of pins and counting blinks on the CEL (The blink pattern will tell you the code). I'm not sure where the diagnostic connector is for this in the 3.0, or what the terminal numbers are, but I'm sure somebody else with a 3.0 will chime in, or try a search.
MTL_4runner Apr 21, 2006 09:01 AM
Get the code, then post back:
http://www.off-road.com/toyota/tech/codes/index.html
