Catalytic Converter
ive got about 176,000 miles on my truck. the cat is making some squeaking noises. i really want to cut the thing off but i dont want the check engine light on. there is an o2 sensor before and behind the cat. what should i do.
Some more info on your vehicle would help year, engine, etc... You should put that info in your signature.
That being said, you might be able to find something like this for your vehicle, but it depends where you live and whether or not your vehicle has to pass any sort of emissions tests. |
like gallant said you can get a mil eliminator that just sends a signal back to the ecu that is similar to what the second o2 would send if you had a good cat
you might be able to gut it but if the cat isn't bad i wouldn't recommend this because they are not cheap to replace if you ever have too you could also see if you can find a test pipe for your vehicle |
squeak, like heat shield rattle ?
just go and drill some holes on the heal shield flange and rivet it, or stick a bolt and nut on there and clamp it |
Originally Posted by BigBallsMcFalls
(Post 51048154)
thanks, sorry about the info. It is a 2.7 and we dont have to pass emissions down here. thanks for your help
My Truck all the sudden lost power and spudders, egg smell from exhaust.. Do you agree that my Cat is probably plugged? All the sudden like.. and right after I got a fill up. Have over 200k miles on it.
I am about to take the exhaust loose and look down the pipe at the cat if possible.. and I may try to gut it... Will this throw the check engine light? is there a way to bypass or flash the ecu?
I am installing my URD PCU O2 sensor simulator... I can't seem to locate the ECU? Can someone tell me where it is? Instructions say its near passenger seat. Darn if I see it, pulled the glovebox and don't see it there either. Anyone? Bueler?
ttt... anyone??
Originally Posted by Ocean Racer
(Post 51317108)
Make sure you solder all connections. This is really not optional if you want it to work right. |
Vehicle year/model info is always helpful for helping locate parts and or trouble shooting. ESP is not working for me. :hillbill:
Hah! Funny goat.
STICK it to 'em |
| All times are GMT -8. The time now is 04:05 PM. |
