Cat converter??
My cat has developed a hole in the bottom of it and leaks kinda bad. Bad news is...my inspection is expired so i guess im up ˟˟˟˟˟ creek right now. Midas wants 170 bucks for a new one with install......i said screw that....and found that i could get a magnaflow for around 75 or soo....im just a little confused on which one i should get....could anyone help with which series i need and something on a single or dual BOSS???.....anyways...thanks for all your help...
shoorty |
I am selling a cat converter if you are interested for $40, then go to a muffler shop and get it welded on.
https://www.yotatech.com/forums/show...threadid=24397 |
I've got the magnaflow high-flow cat sitting on my floor right now. I got mine for just under $50 shipped. I found a company on ebay that was selling them for $32 plus shipping. You might want to check it out.
I'm not sure about the single or dual BOSS thing. You just need a universal one that's 2.25" in and out without the air tube. :bounce: |
Shoorty911
I put a magnaflow on mine and I noticed a difference. but..... From my understanding your cat should not go bad. I have been told that if it does go bad or gets plugged then something is not running right. |
96rr, he said he got a hole in it, not that it was clogged.
Those cats are expensive! The ones I have all looked at were around $50 on summit. Also, aren't highflow cats bad for torque, or is that only on the 4cylinder models? |
