Can I lower SAW's w/1" BL?
It depends on what you are trying to accomplish. If you just want to fit larger tires, then do what Flygtenstein said. If you are trying to gain ground clearance, then the body lift won't help you any and by lowering the SAWs you will lower your clearance.
ok I don't understand something here .. how does putting a body lift on affect your cv angles ... I thought the axles went from the frame to the wheel. Or are the attached to the body?
Hes saying he is going to add a 1" BL to compensate for lowering the saws. Then He will still have the same amount of clearance at the fender for his tires with less stress on the cv's due to the lesser angle of them.
Thanks for the input. Im w/ the bl Im trying to eliminate the slight rubbing I currently have. But like dbikeman said if I can eliminate the rubbing and still lower the SAWs (thus imp cv ang) w/ the bl than Im golden
Thanks again for the input. Anyone whos done what Im thinking about feel free to chime in.
AG
AG
I'd do the body lift and drop the saws, even with the diff drop the cv angles aren't great and I still got some grease seepage. The closer you are to stock, the longer your cv's will last. Also, keeping less tension on the SAWS will soften the ride up a bit as well. You could also install the Revtek Top Out Spacer that will also gain you some lift and drop the SAWS even further. This will make the suspension even flexier, but won't do jack for the CV's.
Thanks Dawgs,
Ive used your (and Schaefers) site for alot of info, if I can drop my saws almost 1" w/ a bl I think its worth it.
I know you got a roger brown 1" did you need the steering spacer and radiator reloc? and what kit did you order?
I hope you eventually get SS's approval.
Thanks AG
Thanks AG
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
Scotttekoch
09-28-2015 10:30 PM
