A/C help needed!!!
Hey,
I got another problem on my 4runner. This time it is an AC system. I live in Los Angeles and I need a fix fast, cuz it's 110 degrees outside. Here is the problem: when I first start the truck in the morning, the AC blows cold air (even though it could be colder), but if I shut the truck down and leave sitting in the sun for 20 minutes or more, when I start it back up, the AC blows almost worm air. But when I get on a freeway it blows cold again. What could be the problem??? P.s. it's 91 4Runner, V6 auto 2wd |
My mechanic said that it MIGHT be:
87240-89127 Rear heater valve But he is not sure. I don't wanna pay $90 for the part & 150 for installation if he is not sure. |
I'm not exactly sure how a 91 with factory A/C should work but unless the rear heater is blowing hot air all the time I wouldn't think it would have any effect on the A/C.
As far as the A/C working better on the freeway I would check to see if there is an electric fan for drawing air through the condensor (in front of the rad). If there is a fan it should activate when the compressor is running. Also check to make sure the condensor is clean. |
How long does it take to get cold? If it's just a few minutes (3-5) that's probably normal in 110 degree weather.
