YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Boost + ECT (https://www.yotatech.com/forums/f2/boost-ect-474/)
Ron(Fla) Jun 20, 2002 03:37 PM
Boost + ECT
From where we live, when we go to 'town", we have to get on I95 and go over 3 overpasses. I had noticed that going up the OP the boost/vacuum gauge would go from vacuum to around 2 lbs boost until about 2/3 way up and then drop back into vacuum and continue on up and over. The trans does not downshift.
A few days ago I had ECT on, which I don't usually do. Everything was as above , except the gauge went up only into "0", no boost at all. Hmmm
Today I tried it again and the gauge either stayed on the vacuum side or into the "0" region. Again no boost to go up the incline.
I am aware that the ECT changes the shift points in the trans, but this would seem to indicate that a different fuel map is used also, since the trans does not shift in either situation.
Has anyone else noticed this?
Dr. Evil Jun 20, 2002 03:58 PM
I haven't noticed any difference, maybe I'll taker a closer look.
AL
Ron(Fla) Jun 20, 2002 07:04 PM
I need to add that this is with cruise control engaged....:redface:
