Body lift noise..
I recently purchased a 99 tacoma and I noticed a clicking sound coming from the back seat, upon closer examination I found that it is coming from the body lift bolt. Has anyone else experienced this? and how do I correct it? Thanks
BTW its a 99 tacoma extra cab... thanks
Since I'm not a fan of body lifts I would say lose the lift, problem solved.
Is the bolt loose ? The noise is coming from the bolt, have you pulled it out to inspect it ? |
Look at bolt, make sure it's tight and that the body lift is a legitimate one not a booty fab one. Might as well inspect all the other body mount bolts too while your at it.
Body mount bolt and you have a body lift?
Regardless, tighten the bolt/nut. Done. :wabbit2: |
I have tightened it, it is very tight. I think it may be the rubber grommet that makes contact with the body. I am going to make me a new one and see how it does. And no its a legit body lift but I may be taking it off, havent decided yet.
body lift sucks!
