Bilstein 5100's question
OK so i see alot of people buying toytech/ eibach springs with bilstein 5100's, to make a 2- 3" coilover setup. I'm seeing the standard ones for my truck, but guys around forums were using the height adustable version. Can someone link me if there are some that'll fit my truck?? i have 96 standard cab 2.4L 5 lug. Or just verify that i'll have the same effect if i use the regular 5100's.
You can download the Bilstein 5100 catalog from here:
http://www.bilsteinus.com/products/t...ht-adjustable/ |
Originally Posted by KZN185W
(Post 52123405)
http://www.bilsteinus.com/products/t...ht-adjustable/ http://www.suspensionconnection.com/...in-tacoma.html |
i dunno how your truck weighs compared to the 1995-2004 Tacoma or to the 1996-2002 4Runner. Because for the 4Runner, the Tacoma 5100s shown in your link is considered to be soft that's why almost all use the Tundra 5100s. The 1996-2002 4Runner is heavier compared to the 1995-2004 Tacoma.
(Post 52123843)
sorry, but i am not familiar with the 4600s. ypu will need to compare the extended/compressed lengths and the damping/valving for both compression and rebound
Originally Posted by cardone
(Post 52123431)
I think i bypassed that sight when i was looking around for them! Found some for $85
http://www.suspensionconnection.com/...in-tacoma.html Do those 5100's come with the spring perches on them or do you use them off the old struts? |
the spring perches come with the shocks but are removable
(Post 52132839)
Right on. Think I am going to order up a set for my '96 Tacoma. I need about 1" lift up front to level it out after some new taller leafs |
(Post 52123843)
Sorry, i had to use this comment to quote again lol. |
I'm not familiar with the eibach springs. You can check with Toytec as i believe they sell the eibach springs.
about the top plate, you will need the original top plates of your truck but you'll need the rubber isolators from a 1999-2006 Tundra, IF AND ONLY IF, you use the tundra coil springs. If you decide to go the eibach route, you MAY OR MAY NOT need the tundra rubber isolators. you can check this out with toytec. Btw, is your truck a Tacoma? |
(Post 52133206)
about the top plate, you will need the original top plates of your truck but you'll need the rubber isolators from a 1999-2006 Tundra, IF AND ONLY IF, you use the tundra coil springs. If you decide to go the eibach route, you MAY OR MAY NOT need the tundra rubber isolators. you can check this out with toytec. Btw, is your truck a Tacoma? Thanks! And yeah it's a 96 5 lug |
(Post 52133211)
Do these 5100's work with 6 lug and 5 lug taco's? Ive got 6 lug. Im also wondering about this tundra talk...I may just pull the trigger on the Tacoma 5100's |
as long as the UCAs and top mount are the same as with the 6-lug, then the 5100s should work fine. please note that there is a 5100 for a Tacoma but has 3 height adjustment rings only
Ok ran into some issues.. SOMEONE HELP !
http://www.tacomaworld.com/forum/1st...-question.html |
