YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Ball Joints (https://www.yotatech.com/forums/f2/ball-joints-1095/)
williemon Aug 5, 2002 01:39 PM
Ball Joints
I need to replace Ball joints on the 90 4 Runner. Any special tools needed? I have a "pickle fork" already. Anybody with instructions? I was told it needs uppers, but I might need to do uppers and lowers.
williemon Aug 6, 2002 01:30 PM
Anybody???:dunno:
williemon Aug 7, 2002 12:31 PM
Anybody at all?? Come on now!! Sombody has to have done this before. How about it....Yoda.....Corey......anybody???:shocked:
paddlenbike Aug 8, 2002 10:01 AM
Ball joints hate me and I hate them.
A ball joint separater is an easy way to remove a ball joint. Consider yourself forewarned though that it will likely tear the rubber boot.
http://www.harborfreight.com/cpi/pho...8699/38649.gif
Use could also use a ball joint puller that looks something like a harmonic balancer puller.
I want one of these:
http://www.harborfreight.com/cpi/pho...8999/38926.gif
$25.99 from Harbor Freight.
All I can say is good luck!
Ken
Corey Aug 8, 2002 10:28 AM
Sorry williemon, never tackled that before.
I thought for sure Paul or Master Yoda may have.
Corey
williemon Aug 8, 2002 10:31 AM
Anybody know if the replacements from the auto store are pre greased, or do I need to zerk them and install some grease? Also, if I do grease them, should I use a synthetic grease that I already have, or use a convintional grease?
zamboni95 May 19, 2003 12:01 PM
I need to replace my ball joint boots. Any advise out there? Any links?
Thanks
Firefyter-Emt May 19, 2003 07:57 PM
Very easy job... The ball joints bolt in to the control arm, and you will need to grease them.. The fitting will come with them, just grease them after you have them all put in.. All you need is that fork tool to pop the joint and a good 4lb sledge (makes the job eaiser than a light ball peen hammer)
Victor May 19, 2003 08:33 PM
Lee is right. Buy a big ass hammer - don't waste your time banging with a claw hammer.
OneTrickToy May 19, 2003 08:52 PM
I used a 4lb maul to seperate my tie rod ends. I'm sure it will be about the same doing the ball mounts.
zamboni95 May 19, 2003 10:13 PM
Thanks for the advice. I'll be doing the ball joints after I manage to install the headers and exhaust. The header installation was working out great until I broke a bolt. ugghhhhhh
Thanks again
williemon May 22, 2003 10:32 AM
I learned the hard way that I needed a BFH!!!! Bought one at sears the next day. Then the removal was easy and so was the install. Guess I need to grease them.....:roll:
