YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   Automatic Shifter Replacement?? (https://www.yotatech.com/forums/f2/automatic-shifter-replacement-54203/)
SD70MAC Mar 14, 2005 04:48 PM
Is there any sort of shifter handle that I can replace the stock one with? I'm kind of tired of the stock computer joystick-looking shifter. I'd love to have something like a Hurst T-handle on there.
jonykarate Dec 28, 2006 12:04 PM
Sorry for bringing up such an old post, but I am also in the market for a replacement shifter for the auto tranny. Preferably one that is not so tall..
mt_goat Dec 28, 2006 12:26 PM
Good luck with that, the wiring for the OD switch is one tough problem and the shift lock stuff is another.
Dublin Dec 28, 2006 03:40 PM
You could put the shorter fatter shift nob from the 2WD automatic 4runner on in its place. Here's mine.
<a href="http://tinypic.com" target="_blank"><img src="http://i18.tinypic.com/2hwd6ch.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
reggie 00 Dec 28, 2006 09:12 PM
how did you do it?
Just the knob or the whole shaft as it attaches to the tranny?
Dublin Dec 29, 2006 04:19 AM
Just the knob, it's pretty tricky to reconnect the wires for the OD (their soldered to the switch) and the screw hole attaching the knob is in a different spot so you need to drill and tap a new one (or a tek srcrew could work). I like the slightly lower height and feel. Be sure you have time and patience to do this(not a quick and easy mod) once you start there is no turning back.
mt_goat Dec 29, 2006 04:38 AM
Is the shift lock button stuff the same for both?
Dublin Dec 29, 2006 06:07 AM
Yes they look different but only because of the knob design. It's just a swap of one complete knob assembly for the other.
jonykarate Dec 29, 2006 04:16 PM
thank you very much for the replies. Hopefully I can find one at a junkyard.
97Gumbi Mar 20, 2022 07:56 AM
With enough Dremel work and a dream.... Anything is possible. 😉🤣
https://cimg1.ibsrv.net/gimg/www.yot...370da4269.jpeg
https://cimg5.ibsrv.net/gimg/www.yot...8b5246032.jpeg
