auto vs. 5 speed
i'm looking for either a 1st or 2nd gen 4runner. it won't be my main driver, but will be my winter 4wd and my summer toy (offroading, dunes, etc.). this is my 1st truck ever and i've got a question for all you experienced guys. which is better for offroading, manual or auto? i've heard different people say different things, and i was wondering what your opinions were. which tranny should i be looking for?
Here's some previous Yotatech threads on the same subject.
https://www.yotatech.com/forums/show...ight=automatic https://www.yotatech.com/forums/show...ight=automatic |
I love my auto for wheeling, very easy to crawl slowly through rocks.
Manuals are much more difficult to use while off roading, but when used properly can lead to better results and lower crawl ratios. More hardcore stuff may necessitate a hand throttle mounted on the shifter, but from what you're saying you won't need anything that crazy.
One thing to think about is the fact that the 3.0 is a fairly underpowered engine, so it needs all the help it can get, a 5 speed could do just that. |
i'm not looking to do anything crazy with offroading. maybe someday when i am a multi-millionaire i'll get around to building a rock-climber, but not anytime soon. my 32 roadster takes precedence. i just want a cheaper truck that can go on dunes that aren't that difficult and one to go through mud and 2-tracks and stuff. nothing too much. yet. gotta start somewhere.
when did they start using the bigger engine (bigger than the 3.0)? i doubt that at this time i'll be able to afford anything beyond a 2nd gen. so that's what i have to work with. with that said, auto or manual? (keep in mind i'm a beginner with offroading)(i'm excellent with a stick on the road, that's not a problem, but i've never driven off-road before)(i have a 94 celica GT, 5 speed. awesome car. i want to get a newer one eventually) |
One thing to think about is the fact that the 3.0 is a fairly underpowered engine, so it needs all the help it can get, a 5 speed could do just that. I suppose if you had some crazy low gears, and you had to shift between gears it could be interesting, as it's more awkward to shift gears in the lower ranges. Anyone know of an article on the topic. I've had two manuals, and would never think of going back until I'm old and tired. Bill |
Originally Posted by bobzemuda
I keep reading things like this, and I'm curious what the instances are that it makes it more difficult. Not having to ride your brakes down hills and the like seems a huge advantage to staying in control to me.
Bill |
Originally Posted by mt_goat
Just because it is an auto doesn't mean you can't still shift it manually. I just stay in 1st gear down steep hills
edit: A Pro/Con list for each sort of thing that is... |
Well, that's an excellent point. I just see all these posts on this and other boards saying automatics are easier to wheel, and I'm just wondering what the reasons behind this statement are.
The best way to fix this is to have a hand throttle, so you have one foot on the brake, another on the clutch, and the throttle is handled by your hand on the shifter. Takes a little getting used to, but can be quite powerful once you've got it. |
manuals typically get a little better mileage too. i just can't stand to drive automatic...i'm a stick guy, and that's the way it will always be. to each his own, though
