Anybody have pics of a 4" lift?
anybody have any pics of a 4" lift or bigger on a 3rd gen 4runner? Idealy what I am looking for is a 3" toytec lift with a 1" bodylift. Or any larger suspension lift... thanks.
I'm not lifted yet, but I would suggest cruising through the 3rd gen members rides. Not the easiest way but what can you do :con:
I'm sure you'll get some posts but it may be quicker to surf through. my .02 |
Pro Comp Stage II 4" lift with 35 x 12.5 x 15 minimal front fender trim no crank on the t-bars will be adding 1 1/2 bj spacers just not got to them yet
http://i184.photobucket.com/albums/x...d/PICT0007.jpg http://i184.photobucket.com/albums/x...d/PICT0009.jpg http://i184.photobucket.com/albums/x...d/PICT0006.jpg Hope thats what your looking for and helps you decide |
If you plan on doing a front spacer lift, I would STRONGLY recommend nothing more than 2.5 inches for the front lift with coil spacers. Alot of guys usually end up with issues with their CV's with 3 inches of spacer lift.
Do a 2 inch Body lift instead of a one and play it safe with 2 to 2.5 inch suspension lift of thats the height you need. |
That looks really good azrunnin. I currently have the 3" Toytec and think I'm going to add the 2" bl when I put on my 285's next spring. Thanks for the picture.
To the OP. Look up pictures for RooRRunner and Neliconcept. Both members are running about 5" of lift and are fitting 35's. |
Originally Posted by 312necro213
(Post 50842913)
Idealy what I am looking for is a 3" toytec lift with a 1" bodylift.... thanks.
http://i276.photobucket.com/albums/k...2/4Runner6.jpg http://i276.photobucket.com/albums/k...ails050708.jpg |
