any1 who changed their drain plug gasket
Old 12-04-2003, 11:16 PM
EDGE's Avatar
I changed the oil and the drain plug gasket seemed to be glued on, it's still the 1 that came with the truck, how does 1 remove it to put a new 1 on I thought it would just come off, I did not want to double it up plus it seems pretty good looks like it's made of metal and looked just like new almost
Old 12-05-2003, 03:28 AM
SLC Punk's Avatar
Are you sure it isn't just stuck on there? My drian plug will stick on the oil pan and I will just pry it off. I think I have changed it twice in the two years that I have owned the rig.
Old 12-05-2003, 09:57 AM
EDGE's Avatar
Well it's stuck on real good, when I 1st got the truck and changed the oil I thought it was part of the drain plug, it is a pretty think peace of metal
Old 12-06-2003, 04:29 AM
The Dutch Man's Avatar
Yeah Edge, I saw that too when changing my oil. My guess is that it shouldn't be removed. Mine stuck to the oil pan as well. I just left it. Recently, I started taking mine to the stealer. For $24.95, and only 30 minutes tops, it's easier to let them do it. Plus, dropping that skid plate is a major PITA!
Old 12-06-2003, 11:30 AM
VolcomTacoma's Avatar
Mine came right off of the drain plug bolt. Mine was changed at the last oil change though, so I guess if it's on there longer it will be harder to get off. I think the washer is some kind of cardboard.
Old 12-06-2003, 01:57 PM
92 Toyota's Avatar
When I buy my filter from Toyota they give me a new washer.The parts guy says they are prone to cracking.???Mine always stick to the pan but I just tap it off.The 2 times I have changed my oil the washer looked fine.
Old 12-06-2003, 02:00 PM
Co-Founder/Administrator
Staff
Corey's Avatar
My dealer changes it every time the oil is drained.
smthwsn357
12-04-2023 02:08 AM
Whatever123
09-30-2015 12:12 AM
09-04-2015 09:27 AM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: any1 who changed their drain plug gasket
