Alignment Issues...
So i went to discount tires today, same guys that have done alignments on my other trucks, and they adjusted the toe, but the camber/caster still seems outta wack, like they're still slanted slightly like this - \ /. I dont want my new tires to get eaten on the outer edges. The tech said they cant adjust the caster any further out. Does this seem right?
The guy said i could get bigger washers - the ones on the lower control arms that adjust the camber/caster - and he might be able to adjust them out? this is on my 98 4runner v6 5spd 4x4 with my SAW's cranked 1.75" over stock, and OME 891's rear . |
Do you have the print out on the alignment?
| All times are GMT -8. The time now is 01:04 AM. |
