Old Apr 1, 2016, 08:39 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
Print Wikipost
ABS Light Code 4 9 What is this?
Old Mar 27, 2007 | 10:47 AM
NorCalJ's Avatar
99 4runner 2wd v6
abs light on all the time
pulled code 4 9
Please someone tell me
1: what the book says this is
2: anyone who has fixed this code before if there was an easier or different solution (such as cleaning a sensor instead of replacing.)
Thanks!
Old Mar 27, 2007 | 05:41 PM
My814x4's Avatar
Check and see if your brake lights work , the code is for the brake light circuit possible brake light switch.
Old Mar 27, 2007 | 05:50 PM
DeathCougar's Avatar
From Techinfo.toyota.com
Code 49: Open circuit in stoplight switch circuit
Trouble area: Stoplight switch, Stoplight switch circuit
Old Mar 27, 2007 | 07:19 PM
NorCalJ's Avatar
ABS Light >>> code 49
Hey thanks guys Ill test the switch. I very sure my brake lights work, but I know most brake pedal switches are double pole so maybe the secondary switching for the ABS coomputer is bad.
How do I reset this code so I can test any repairs????
Old Mar 28, 2007 | 05:29 AM
RETRO's Avatar
Disconnect the battery cables ro reset...
Old Mar 28, 2007 | 06:16 PM
NorCalJ's Avatar
I left both battery cables off for over an hour, The light is still there, even when I first start the car before pressing the brake or anything.
Someone please explain exactly how to reset the abs light.
My brake lights work fine.
I took the brake switch off the pedal and tested with a multimeter... everything seems like it worked fine.
In my past experience, when you have a code like "Open circuit in stoplight switch circuit" there are usually one or maybe two very common points of failure. Anyone with experience repairing this excact code.
Thanks.
Old Jul 19, 2024 | 06:15 PM
Joemaint's Avatar
Help
Anyone know how to get rid of this. My abs is not working properly all lights are good but abs is no hood
smthwsn357
May 1, 2024 07:28 AM
raptor510
Feb 17, 2017 07:11 AM
AkitaDog
Sep 1, 2015 08:05 AM
ty1er
Aug 1, 2015 11:53 PM
nonstop
Jul 24, 2015 06:29 PM
