YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   ABS computer module differences with elockers (https://www.yotatech.com/forums/f2/abs-computer-module-differences-elockers-165381/)
pillguy Jan 27, 2009 12:25 PM
Hi all,
I am switching out my rear axle for an elocker axle on a 97 4runner v6 with 4.10 gears. The question I have is should I swap out the computer modules that control the ABS system as well? Ie is there a difference between the ABS computer modules on 4runners with and elocker from the factory and ABS computer modules on 4runners without and elocker from the factory.?
Also, does anyone know where you can get the frame harness from?
THanks,
pillguy
eric-the-red Jan 27, 2009 04:15 PM
I swapped the axle in my 2001 for a 99 with the locker, and the ABS is just fine. I don't think there is any difference in the ABS control systems.
As for the harness either a used one at a wreckers or the dealer.
