98 4Runner fishtailing problem
Old Oct 20, 2009 | 09:54 PM
wolfrunner's Avatar
the main adj for the rear brakes is inside the drum. its called the self adj. bad thing about toyotas and alot of vehicles is that they dont work too well. sounds like you just need to adj you rear brakes. go some where that does brakes and pay them 10 to adj them.
Old Oct 20, 2009 | 10:29 PM
evanB's Avatar
Yeah, I think I'll take it in. I'm sure I'll need a brake job if the previous owner had it like this for a while but I'll just get it adjusted for now. Later I'll do some reading to see if I can handle the whole job on my own.
Old Oct 20, 2009 | 10:32 PM
Elton's Avatar
yea the drums are a pita to get off but theres threaded holes on them for a reason if you can find bolt that fits u can thread it in there and it should pop the drum off
Old Oct 21, 2009 | 01:31 AM
ESQ's Avatar
ESQ
Yup. There are a couple threaded M8 holes in the drum. Screw 2 M8s into them, and they will push the drum off the hub.
Slap some antiseize or grease on those threaded holes when you put it back together so the threads don't rust out. I usually use them when i pull my drums.
Old Oct 21, 2009 | 12:50 PM
  #25
evanB's Avatar
Originally Posted by Yukon
Looks like you have fluid coming out of your drums. Have you ever changed your rear axle seals? Might need to now, as that fluid will leak out and ruin your brake pads.
I took it in and they confirmed your hunch. The axle seal was bad and the oil screwed up the shoes and caused them to grab/overheat.
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
