'97 T4R Intermittently Dead
1997 T4R SR5, Manual.
I've been doing some digging and am not sure if my issues are interrelated or not. Seems might be electrical-related but not sure. I am hoping to avoid dropping off at some shop and cost $$$ so coming to the ultimate wisdom of the forum. :) 1. One month ago out of the blue, I came out of store and truck acted dead when turned key...no clicking, no sounds, no lights, nothing. Fired right-up with a jumpstart and I was back on the road. I did not have to reprogram my radio stations so that's why I said "acted" dead (instead of full dead then having to reprogram everything). Been running perfectly for the last month and then again yesterday, BAM!, same thing. Dead. Cycled the key ~ 30x to see if system would kick on (read here that some people with starter issues, it would start after repeated tries at starting). That didn't work. After another easy jumpstart I am back on the road but wanting to hopefully avoid another repeat. Any idea what is wrong??? 2. Driver's door lock ONLY works by turning key from driver's side door. From passenger door, nothing. From pushing button on console, nothing. All other door locks perform as supposed to. Some have said this is bad actuator?? 3. And here's the weird one...(bit of background first...my truck is originally a "Gulf States" T4R so it came with the dealer-sold/aftermarket alarm system). The remote had some quirks so for many MONTHS I got tired of dealing with it and just flipped the little switch underneath the dash that disables the system and for months been using key to lock/unlock the doors without issue. Anyway, I was walking back from beach that day...turned the key like I always do this time when I turned key the alarm system went off (amongst hundreds of people btw, ha)!! After ~ 20 min another T4R owner walked by and lended a hand. I ended up just disconnected the whole alarm system...luckily it started, and as I write this, I have not touched the system since then. I would LOVE to replace it with a better/newer system but haven't dug into that one yet (if anyone else had, is it difficult to replace with another system?) I've owned my gem for 6 yrs. (Oct. 11) with no issues. Seems it kinda started acting up after I disconnected the alarm system that day coming back from the beach. Anyone have any insight into helping me rectify my situation? Thanks!! |
Have you checked that your clutch safety switch has not vibrated loose .
Meaning you really have to get your foot on the floor Loose or dirty battery terminals Loose or dirty ground connection on the block:wrench: |
Was gonna suggest battery cables like my homeboy Wyoming suggested. They can look and feel tight but be full of corrosion under the collar and on the battery post. Clean asap.
Originally Posted by vasinvictor
(Post 52289889)
Originally Posted by wyoming9
(Post 52289885)
Meaning you really have to get your foot on the floor Loose or dirty battery terminals Loose or dirty ground connection on the block:wrench: Terminals look/feel clean/tight. I will also look for a loose/dirty ground connection on the block in the AM but will be surprised if something shows. |
:wrench: Not knowing just how your alarm works .
Does it disable the starting system ?? If it is not the simple like a poor connection I would look at the alarm system being the problem. How many miles ?? |
(Post 52289980)
Does it disable the starting system ?? If it is not the simple like a poor connection I would look at the alarm system being the problem. How many miles ?? I will hit 180k miles within the next day or so. |
