YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   97 4-runner w/ 5sp & 5vz-fe clutch issues (https://www.yotatech.com/forums/f2/97-4-runner-w-5sp-5vz-fe-clutch-issues-155185/)
johndeerejake Sep 22, 2008 06:07 PM
Today I was driving home and was going up a hill and felt some slippage in 5 gear as well as 4th.
I am curious about what this may be. My first guess is the clutch, I am new to the ownership of the yota and was told by the previous owner that he replaced the clutch 1.5 years ago. I am calling BS on that. But before I tair into the clutch I was just wondering if there other things I should check before I do this.
Help is much appriciated.
DeathCougar Sep 22, 2008 06:36 PM
If its slipping, I would be looking at the clutch. First, make sure the clutch is adjusted to specs according to your factory service manual. If it is, then i would look at the clutch. If he used a cheap taiwan clutch and was hard on it, 1.5 years of abuse will certainly wear it down faster than normal.
johndeerejake Sep 23, 2008 05:53 AM
That is what I am guessing he did as well. I have looked as some Exedy clutches, but what other after market clutches would be worth looking at?
I am turning 33/12.50x15's
