92 4R injector leaking. What do I need?
Hi group,
My 92 4R that I bought earlier this year started having a gas smell when running and I noticed a 40 mile per tank drop in mileage. Suffice it to say that was enough to pull it into the garage and start taking things apart. Pulled the intake off yesterday and had my b-in-law watching under the hood. Looks like #6 injector is spewing fuel. I figure I may as well replace all of them at once to save myself the hassle of pulling the intake again. Any recommendations for injectors? Local Stealership wants $169 EACH!!! Autozone has rebuilts for $50 each and BAP Import has Pythons for $65 each. Any other words of wisdom? Thanks all... Nvision Mesa, Az |
Send them off to be cleaned and flow matched.
www.injector.com and http://www.doaracingengines.com/ are 2 that come to mind. I had mine done and it cost me around 150 for the entire set of 4. |
you don't need new ones unless there damaged all you need is the "rebuild kit" which is all the o-rings, and have them cleaned at a shop.
