90-95 engines and models
So I really want one of these trucks with a 22re 5 speed combo. Great mileage, ultra reliable, so I hear. Two questions:
With an ext. cab 4x4, driven carefully, what sort of mileage can I expect? Did Toyota make the SR5 truck with a 4 cylinder? And a follow-up, if they didn't (or its really rare) how hard is it to change a truck from a V6 to a 4? Does everything fit okay? Gearing no problem? Thanks alot |
The 22re should last for well over 200k if it was taken care of. I pretty sure they are out there. I believe the 22re was used until 1996. Good luck in finding one. Don't know about the engine swap thing.
if you change motors you will need a new tranny transfer case and a computer and some other stuff
so your wanting something like this ? http://www.autotrader.com/fyc/vdp.js...000&cardist=69
If my memory serves me correct, 94 was the last year for the 22re, 95 went with the 2.7L.
And no, the 4-cyl was not available in an SR5. |
yes, the 4 cylinders were most definitely available with the SR5 package! they are a little less common than V6 SR5 trucks, though.
extended cabs are more common with the V6, but finding a 4 cylinder truck with an extended cab shouldn't be too hard. my '91 regular cab 4x4 with the 22R-E gets about 20mpg on average right now. when i bought it in august, it was getting closer to 23mpg, i blame the terrible winter fuel for the mileage drop. |
Originally Posted by rockota
Nope. 95 was the last year for the 22re, the taco and 2.7 came out as a 95.5.
is the sr5 model just power windows and locks ?
Rockota read Elton's Post for Autotrader :great: opps didn'f fully read post! :drunk:
http://www.brian894x4.com/page15top.jpg
look, there's a column for Xtracab SR5 V6, and Xtracab SR5. they were most definitely produced. that said, the only real upgrade the SR5 has in those years is a tach and a couple extra gauges. i'm not a big fan of the chrome fender trim, a lot of trucks have it missing/falling off, and it looks cleaner(imho) without it. |
HAH I knew I was RIGHT! :baby: j/k Wait I use to have one until Iflipped it in a ditch! :con: :rockin:
My father put 340k on an Xtracab SR5 22RE 5 speed. Average mpg was 19-21 year after year.
So they made them, but they were really rare. Darn. Any way to put power widows/locks into a deluxe model?
One more question - how much better is the 2.7 and 3.4 in the slightly newer tacos? I'm driving a T100 right now with a 3.4 and it's getting like 18 in city and 20 on highway, and has heap-good power. I haven't heard much talk about the 2.7 - is it a good engine? Would a 96 or after Taco get better mileage than the 22re? What are the pros and cons between the 22re and the newer engines? I know back when I was a Ford truck man I was all into the 351 windsors they put into the pre-96 trucks - I never liked the idea of the 4.6 V8 and stuff. |
The 2.7(3rz) and 22re are both great motors. Between the two motors it is hard to say which is better, maybe they are equal in terms of reliability. I would urge you to go for a Tacoma with the 3rz for several reasons. I had a 93 4x4 w/ 22re and a 95.5 and 97 tacoma w/ 3rz, now a 00 runner w/ 3rz. For me I like the 3rz better, not saying it is better, what I like is the extra power, 150hp vs 116, and the smoothness of the motor. Also the Tacomas are a bit larger so they ride better and the coil over front suspension is an improvement IMO. Heres a few points in favor of the 3rz, after 96 they had direct ignition, timing chain guides are metal unlike plastic in the 22re and the 3rz is a non interference motor. Now there is a running argument on that last point but I believe the concesnus is that the 22re is interference.
Wow. Sounds like the 2.7 is a real winner.
Does a post 96 truck get better gas mileage with a 2.7 than with a 2.4? |
the 2.7 may get better gas mileage simply for being a newer motor but there will not be much difference between them, at least i didnt notice. They are both great motors, but i like the 22re better and especially more so then the v6 in earlier models. I dont know why this is the case, probably where i just grew up and know 22r and re and know they are invincible, also i dont like new things and in the early 90's the v6 is new, mind you it is still a great motor and probably just as good but is just the way i feel/felt.
My 88 4Runner SR5 doesnt have power windows/locks, and my brother's 84 SR5 4Runner diddnt have power locks/windows. |
Does a post 96 truck get better gas mileage with a 2.7 than with a 2.4? power windows suck, you want the crank windows for sure. |
