5W to 10W bulb question
I want to put a brighter bulb in my interior light outlet at the mirror on my regular cab Tacoma.
The fuse type standard bulb is 5W.The 10W is a little bigger but I can get it to fit. Would the 5W difference be too much for the outlet,heat etc..? |
The fuse type standard bulb is 5W.The 10W is a little bigger but I can get it to fit. Would the 5W difference be too much for the outlet,heat etc..? That bulb will be twice the amperage (5w/12v=0.42 amps) now (10w/12v=0.83 amps). It will likely be insignificant but good to check anyway. |
