5vz aftermarket temp gauge help.
I have an electronic temperature gauge I want to hook up to my engine. Can I splice the aftermarket gauge wire into a factory sending unit? If so, where is it? I've heard there is one in the back of the engine and one right behind the timing cover.
Thanks in advance. |
If you are referring to what some call the water temp sending unit, its a small white plastic connector that gets its ground through a small metal tab on the back of the plenum. Hard to see, even if monkey'n on top of the engine.
Is the secondary gauge to see digital readings? |
It is NEVER a good idea to bastardize the factory wiring harness. Run your own wire.
What makes you think that the factory sending unit output is compatible with your aftermarket gauge anyway???? |
Originally Posted by millball
(Post 52419754)
