550cc supra injectors for 5vz-fe
hey guys, i am in need of bigger injectors and have been told by LCengineering that i need 550cc injectors and i do believe there should be a supra injector that should fit this situation. if anyone can point me in the right direction it would be greatly appreciated!
I didn't use these in my S/C 3.4 L , but I did use these in my 7MGTE
http://www.rceng.com/ 550 's 550's might be to big though , depending on what your doing ? I have some larger URD injectors for the 3.4L , brand new . oversized they are 318 .. by the way they are for sale . I also have some stock 7Mgte injectors (good used) for sale , I believe they are 320's ? . |
With the TRD supercharger there is no way in heck you need 550cc injectors. The TRD SC is lucky to crack 300whp. 550's are good for around 550whp.
If you have the supercharger don't mess with any injector upgrade, get a 7th injector. By far the easiest, most hassle free and best preforming setup besides meth injection. I see you have meth injection already though, you could just install a ~14gph nozzle and run pure methanol as well. |
What will you be using to control those monsters? I run dual nozzles totaling 22gpm of straight meth for my fueling and works like a treat. I'm making 350+whp by estimation.
Doing haltech standalone ecu. Custom higher compression pistons, forged crossbeam rods and head studs. I have talked to lc engineering a techs several times and this is what they say. I will still have the methanol but will be using it less than I am because I'm tired of running through it so often.
Originally Posted by toyotanick
(Post 52216931)
I am not seeing where you will get any return on investment? Also going with higher compression with the supercharger is not a good idea IMO as the outlet temps from it are already stupid high at 300f++ and knock is hard enough to keep at bay as it is. But your money, up to you. |
the guys at LC engineering build some pretty awesome motors and they are telling me it will work fine with no issues as long as i feel my tuner can do it. i want all forged internals and head studs for insurance and i keep blowing headgaskets... the higher compression will help me on the interstate as well. but what i am getting at is i am trying to find a set of injectors...
So you just need a set of 550cc injectors?
I'm guessing you don't want to pay a 'new' price for them? Otherwise, just go buy some. I've had great service so far from my 1000cc injectors (for my MS3x/2.3L/350 whp/E85/Turbo Volvo) from this place: http://racetronix.com/products/ Very reasonably priced, sold in flow matched sets, lots of options in styles and flow rates. |
awesome, thank you JOMOKA thats basically what i was looking for.
(Post 52217034)
Now if you were turbo then it would be a different ballgame. Although you would still want to keep compression around stock, going much higher on pump gas is a game of diminishing returns. |
i havent worked out all of the details just yet but i know the horsepower numbers i am wanting and what i am wanting it to perform like since this is an everyday driver. do not plan on turboing it ever because of recent terrible experiences with my STI and also what i do with the truck a supercharger fits a little better.
(Post 52217087)
Turbo works great if done properly. Just got to match the turbo to the goals. Plus the extra displacement of the V6 really means that lag is an almost non-issue. |
I'm not in the situation to be building an exhaust manifold and all the extra crap that comes with a turbo setup. I think this setup will do exactly what I'm looking for
But thank you ace.
(Post 52217072)
(Post 52217118)
That supercharger is already tapped out in the mid 200's. It should have come with an M90 supercharger like pretty much every other V6 SC application. |
ill have a set of 440's available soon from my jdm 2jzgte. im putting in 550's with a resistor pack and will have no use for the 440's. they will be sold for the price of shipping to a fellow yotatecher. let me know if you might want them
What ever happened to "tragger" (or whatever the screen name was) - guy took a nearly new '00 4Runner and had a shop build a twin turbo motor for it, Ford 9" rear end, etc.?
Andreas |
It should have come with an M90 supercharger like pretty much every other V6 SC application. Had mine from the very begining (still do) and being apart and watching all the threads over multiple forums, those two statements are the bottom line period. They will save you a lot of money. No bias, just been ther done that 10-12yrs later. |
Originally Posted by aowRS
(Post 52217628)
Andreas Met them both at SEMA and picked up one of the first if not the first splitsec piggyback and 6 injector kits in vegas. Long time ago so don't remember the exact year, maybe 03'. I wonder where it is now..... |
