50k Maintenance. What else?
hey guys my truck is just about to roll over 50,000 mi. So I'm going to treat it to a little Maint. Here's what's on the list.
1. Change Sparkplugs 2. ATF flush A. Clean magnets B. Clean filter (or should I replace?) 3. Oil change A. + oil filter 4. Lube chasis 5. Check front brake pads 6. Clean air filter (true flow) Can you think of anything else? Thanks everyone. |
Have you flushed your power steering fluid?
Diff fluid too.
I haven't heard of flushing the power steering. I could do that. Just take the line off the bottom and drain it or what? Ok everyone what type of diff oil do I use? Thx for the reply hilix 808.
PCV valve and EFI filter. If you've wheeled in water flushing the brake fluid is not a bad idea either.
Gerone |
