40k routine maint CEL
99 4runner 2.7
its got roughly 46k on it at 40k the CEL came on from my guess it was one of those routine maint things the same thing hapend on our 04 sienna that i fixed but for some reason i cant seem to figure out this one. anyone experience this and/or know how to get rid of it ? |
What code was it?
honestly
i didnt pull codes like i said the cel in our sienna came on at 40k also and so did this one in the 4runner so i thought it would be safe to assume it was a routine maint thing its been fine for the last 6k miles seriously |
Im, not sure, i would still pull the codes.
at vatozone or what ??
lol anyone else have the similar cel and turned it off themselves ? |
Originally Posted by scuba
(Post 50821814)
lol anyone else have the similar cel and turned it of themselves ? dood just....doood :bang: |
oh gosh
what now ?? oh nvm EDITED lol but seriously theres some sequence, like key in ignition,hold down trip button ignition on. something like that please help |
come on now Don't just clear it hoping the problem will go away. Obviously there is a problem and thats why the check eng lite came on. There is no 'routine maint' lite or anyhting routine about the check eng lite. Get the code read and get it fixed
ha
prob is my mom took the keys so as soon as i get them back i will do so |
yeah there is
open driver door key in ignition, off close driver door open driver door then close it again Then, turn key to ON. next push trip button and hold it turn key off, then on and then the engine light will blink out the code some fast blinks then a pause, then the next set of blinks 5 fast blinks in a row, then a long pause, it is at then end then repeating good luck |
huh i have never heard of that on a Toyota. I have seen tricks like that for some OBD I or if you jump connectors.
Originally Posted by BigBallsMcFalls
(Post 50822083)
yeah there is
open driver door key in ignition, off close driver door open driver door then close it again Then, turn key to ON. next push trip button and hold it turn key off, then on and then the engine light will blink out the code some fast blinks then a pause, then the next set of blinks 5 fast blinks in a row, then a long pause, it is at then end then repeating good luck You forgot to mention that you have to be barefoot and 1 hand on your head. count to 10 5 times then count to 5 10 times. But never ever say seven 7 times and 9 three times. That should do it. Keep us posted on your progress. |
On the 3rd gen, there is no routine maint Light, Just the Check engine light. You will have to Pull the codes and fix the Problem to get it fixed. You can clear it but chances are it will come back. the fact that it is 40K is coincidence.
alright
well warriors was right went to vatozone codes PO 441, 446, 450 ill try searching but wanted to let everyone know what happened |
well whew we can all rest now..it is SCUBA destroying the ozone layer after all
------- bad gas cap or not tight leaky evap hose (most likely cause) there are at least 5 hoses to check cracked charcoal can bad evap pressure sensor most likely....will cost you some time checking and replacing hoses NOTE: if dtc was detected when cap was loose, then it was tightened...the EVAP readiness test won't complete and reset the light for a while. evap test takes a long time to finish. depending on how you drive and how often you tank up, a week or two. so don't sweat it, and don't consider job done till you drive a month with no further codes OR you get I/M readiness to READY best to clear code and just see if you go to I/M ready in a month after you find the root cause and fix it |
its the original gas cap and it clicks everytime
so i dont think thats it ill check all the hoses and whatnot when its not dark i was reading about 441 on another thread so ill try and figure this out i miss my 91 its so easssy |
| All times are GMT -8. The time now is 01:25 AM. |
