3rd gen headlight removal question
Im going to be installing a new light setup and wanted to know if it's possible to remove the headlights without removing the grill. I have a front guard and it'd be a pia to take that off to get to the grill. Thanks :banger:
you have to remove the grill. the grill is attached to the headlights.
and BE CAREFUL when removing the grill cause the plastic clips like to snap if forced. Take your time with a small little flathead and it should go smoothly!
Oh that is so brokeback. Sorry that you have to take off the grill :(
lol. Im doing the same thing next week! with my 99-02 headlamps!
that blows. :) then I have to do it all over again to get my bumper painted :( thanks guys
that really does suck, it took me like 2 hours last time to put that stupid skid plate on with the guard :barf: |
One more question, is it pretty straight foward on taking them out.
yup, look at the very bottom, push on the clips n pull em out gently and then do the top. should slip right off. unscrew the plate things below the healights n pull em out. take out the screw on top of the corners, pop em off, and u have access to all 4 bolts holdin the headlight on
i meant grill guard + skid plate :)
