3rd Gen. Fan write up
I have a '99 Ltd and I need to remove the heater/blower fan.
I checked the tech write-up, but it's comeing back "cannot be found." Can someone post a tech write-up reference 3rd gen fan motors? |
Originally Posted by Potomacduck
(Post 51057078)
I checked the tech write-up, but it's comeing back "cannot be found." Can someone post a tech write-up reference 3rd gen fan motors? However, this is a perfect opportunity for YOU to do the job, take pictures, and do a write-up. Use a fsm and get it done! |
You don't really need a writeup to do this job... you'll see that it's pretty easy. The hardest part is bending your body to get your head under the dash.
Here is a writeup you can read before starting. You don't need to remove the glove box to do this job. The fan and motor can be pulled out towards the bottom after you remove the three bolts. |
Thanks GS.
Much appreciated! |
No prob. Good luck.
That reminds me that I've gotta do mine soon too since it's never been done.
