338mm x 32mm 4runner brakes fit 1st gen Tundra?
As the title say's, will the 338mm x 32mm 4runner brakes fit the first gen Tundra?
Regards, Kent |
Switching from stock 4Runner brakes to the bigger '01 Tundra brakes is a common swap. I don't remember what size the original 4Runner brakes were. It helps better if I know what year/model you are pulling from and which model/year you are trying to fit them on.
The question I was asking delt with my 2004 Tundra and if the 2012 Gen 5 4runner 338mm x 32mm rotors and calipers were a direct bolt on to the 2004 Tundra.
Regards, Kent |
Ah, then that gen is out of my wheelhouse. Perhaps you could check the appropriate sub-forum: Gen 4 4Runners and Gen 5 Tacos
Thanks, I'll try there.
Regards Kent |
