YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   22re intake manifold question (https://www.yotatech.com/forums/f2/22re-intake-manifold-question-54827/)
Boosted Chemist Mar 21, 2005 04:14 PM
I found in my lower intake manifold, there is a chip next to the gasket. If i spray starter fluid in it, the truck idles perfect. Can i use any lower intake manifold to replace this or is it specific to my truck 94 22re (i know the intake design changed early 90s late 80s)
Ps does any one have a cheep intake manifold they wanna unload to me :great:
thanks
Boosted Chemist Mar 22, 2005 02:20 AM
bump any ideas?
redplastic2p3t Mar 22, 2005 04:13 AM
lower intakes are all the same in the efi years, if i were you i would pull the upper off, and replace the gasket using a gasket sealer called plyable non hardning permatex, it should fill the hole and make an excellent seal, the only prob with it is when you go to take it back off, it will be a mess to clean, but hey its doing its job, and a helluva lot better than rtv
03_4x4Runner Mar 23, 2005 07:37 PM
The only intake that was different was the turbo manifolds, they had provisions for a bigger injector
