| motrhedx81 |
May 24, 2004 06:55 AM |
2" or 3" ?
I've been pondering for a while and can't figure out if I need a 2 or 3" body lift. Either way its going to be an RB lift. I've got about 5" of suspension lift with the 4" kit and 1.5" rear shackles and a little cranking. My 35's fit fine but rub on susp compression and tight turning. Would a 2" lift keep me from rubbing on compression or do I need the 3" for that. I don't know if that extra inch of body lift would make it a bigger risk for rollover on a trail. I know the higher c.o.g. raises that risk and I have my tires set out pretty far for that reason. I guess my main question is; Will I see any rubbing with just the 2" BL?
