1999 4Runner Limited stuck in “AWD”
Hey guys, new to this forum but have been on many others for years. I recently purchased a 1999 Limited 4x4 with rear E locker. Since purchasing I have realized the 4Runner is stuck on 4WD with the center diff open “AWD”. The Dash light is flashing constant with no change apon moving the transfercase shifter or button on side of shifter. I have searched multiple forums including this one, high and low trying to diag and test as much as possible before creating a thread. I have tested all vacuum lines, Voltage at VSV’s, replaced front diff switch, tested the 2 switches easiest to get at located on the transfer case actuator, and have also jumpered the switches located at the top of the transfercase with no result of any kind. I’m leaning toward the transfercase actuator motor/gears being the failure. With that being said I can’t seam to source that actuator any where except the dealer ( for nearly 1000$ ). Does anyone know if I can take a transfer case from an SR5 that doesn’t utilize the AWD function and this actuator and replace it? If so does a module need to be swapped as well? Any input would be amazing, sugfestions, options, things I may have missed. Thanks for your time, -Blake |
Actual actuator failure seems to be low for these symptoms. If you follow thru this thread:
https://www.yotatech.com/forums/f2/4...er-ltd-131201/ (apologies for it being a dozen+ pages) You'll find that most of the time the dealer recommends replacing the actuator because there isn't a step-by-step repair and diagnosis for this symptom, i.e. blinking 4wd lights and failure to shift appropriately. From what I have gathered (and others before me @99SC4Runner, @TheDurk, etc) the position switches (or sensors more appropriately) are the number 1 failure point. There is 1 on the front diff, 4 on the transfer case, and 1 on the rear e-locker. You need to take each out, clean with contact cleaner, and test with a meter for continuity thru the full range with zero dead spots. Next in line is the limit switch paths in the actuator. Post #69 in my build thread has some pictures (https://www.yotatech.com/forums/f200...11/index2.html) Finally is the actuator itself. You are talking about a nearly 20 year old electrical component so it's possible it could fail, but unlikely. When I was at my wits end with my issue, I checked with some eBay sellers for a whole used transfer case. They would honor the actuator's functionality under there warranties because the actuator is an integral component even tho they typical do not warranty electrical parts. |
Originally Posted by fierohink
(Post 52396204)
(Post 52396204)
Next in line is the limit switch paths in the actuator. Post #69 in my build thread has some pictures (https://www.yotatech.com/forums/f200...11/index2.html) Finally is the actuator itself. You are talking about a nearly 20 year old electrical component so it's possible it could fail .
When I took the 3 10mm bolts off for the cover, I didn't take anything else out, just the cover with the 3 brass contact pins. Then with some really fine emery cloth I shined up the contact traces. If you are too aggressive you'll wear thru the tracks and destroy any chance you had of salvaging the actuator. I can't say I played around with any other components inside once I had the cover off because I felt the tarnish was a pretty good indicator of my troubles
I’m having the same issue I changed my transfer case all the sensors on the tC and front differential and what I noticed is that I’m only getting voltage to the blue vsv so the 4wd vsv is always getting vacuum i also changed the 4wd vsv anyone can help me with this ?
