YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   02 replacement question (https://www.yotatech.com/forums/f2/02-replacement-question-197162/)
hurricanes99 Nov 20, 2009 08:43 AM
Just replaced the air / fuel sensor on my 99 4runner. Would there be any reason I should disconnect / connect the battery after the replacement?
Thanks.
Tubbyfatty Nov 20, 2009 09:13 AM
Im guessing no unless your CEL is on. You could if you wanted to but I dont see the need.
I could be wrong tho, I dont know too much about the 96+ OBDII systems.
Elton Nov 20, 2009 09:23 AM
id just pull the efi fuse for a min
hurricanes99 Nov 20, 2009 09:25 AM
I didn't think so either, but I read another post where the original poster said he pulled the EFI fuse and disconnected the battery. I'm not going to worry about it...
brian2sun Nov 20, 2009 02:57 PM
It just takes longer for the computer to adjust to the new info, but it doesn't really matter.
rjkjoe Nov 20, 2009 04:22 PM
No need to reset...It will automatically go off after a few miles after the computer adjusts....
