YotaTech Forums
-   95.5-2004 Tacomas & 96-2002 4Runners (https://www.yotatech.com/forums/f2/)
-   -   02 4runner mods (https://www.yotatech.com/forums/f2/02-4runner-mods-183866/)
EMTJeremy Jun 7, 2009 02:26 PM
02 4runner mods
Hey all, I'm new here and had a couple questions about my 02 SR5 4runner.
I've been reading about the LED mods for the dash and gauge cluster. Seems pretty easy, as I've taken mine apart. I wanted to modify my gauge cluster, but using an OEM cluster from another Toyota (newer Corolla or Camry). Would this be possible to just plug-n-play? or would it be the same difficulty (if even possible) using a Civic cluster vs a Camry for example?
Also, I wanted to add under-dash blue LED's. Where can I get this kit from? I've seen a few online with the strips but those look way too bright. I want to wire it to where they turn on:
-when the door opens, OR
-when I turn the headlights on.
Ideas?
Also, is it possible to add a towing package to my 2wd SR5? I think I've seen the wiring in the back but I'm not sure. If so, about how much does it cost, and is it a DIY project?
Thanks in advance for your help! This thing is my baby and now that I own it (still owe about 5k on the credit card) I want to do a couple things to make it my own.
Thanks!
Jeremy
skjos Jun 13, 2009 11:24 AM
You should be able to find a tow hitch at the junk yard for pretty cheap, installation is simple provided the wiring is available.
Locate hitch, fasten with (8) bolts and you're done.
EMTJeremy Jun 14, 2009 08:43 PM
Cool, thanks
