Zytra's 90' Pickup 4x4 3.0
Old 09-17-2018, 01:19 PM
ZUK
ZUK's Avatar
Got a nice smooth 10 in/lb of pinion bearing preload start torque. Ding the new nut and this end is complete.
RTV on the rubber grommet really helps the rubber plug push thru.
With the 3rd mounted in the axle hole, this is in the 12 o'clock straight up position.
Carrier bearing preload and Backlash is juggled around here. BL measured on every other tooth and recorded.
Testing of the Harrop. Almost every one of them checks in at about 3.9 ohms. That means it draws a tiny 3 amps or slightly more from a 12v battery.
The Nitro battery.......
Old 09-17-2018, 01:27 PM
ZUK
ZUK's Avatar
12 volts is applied..............
Then I turn the pinion....which turns the ring gear......and forces the 3 spring loaded pins up into the case. (The ramp ring is held tight by the electro-magnet on the left.)
The pins are fully in
Continued turning now forces the ramp ring to turn. That's the way it was designed to work.
Removing the 12 volts causes the 3 pins to snap out very quick.
Old 09-17-2018, 01:34 PM
ZUK
ZUK's Avatar
One final pattern check with fresh yellow paint.......The drive side is nice.
Coast is excellent. Not bad for used gears.
Some measured specs are inscribed on the ring.
You would think I know this "brand"....but never saw it before. Is it a Ninja gear?
Zytra's measured specs.
Old 09-17-2018, 01:39 PM
zytra's Avatar
Thanks ZUK!
the guys I bought the axle from wasn't exactly sure what vehicle it was pulled from. It went on a SAS and he said it was originally a 83 axle, but that's the extent of the info I got
if you've never seen brand, I sure can't know about it haha
Old 09-17-2018, 02:40 PM
  #25
ZUK
ZUK's Avatar
I can send it out when I get that UPS tag
It's a good looking diff right now.....
Old 09-17-2018, 02:57 PM
  #26
ZUK
ZUK's Avatar
Makes sense, Zytra....the 83 model had the factory solid collars already in the 3rds and so that's why you have a really good diff with a Harrop and a solid collar
It's only my opinion, but I say try the factory 3 piece drive shaft with the center carrier bearing and see how that works. To eliminate it means a really long 2 piece and those are hard to balance....and keep the rocks away from.
Old 09-17-2018, 03:58 PM
  #27
zytra's Avatar
Thanks ZUK
Label will emailed to you shortly
Old 09-17-2018, 03:59 PM
  #28
zytra's Avatar
what about the front, just grind/clearance the C/V and U joint + 10" spline kit?
Old 09-17-2018, 04:50 PM
  #29
ZUK
ZUK's Avatar
Yep. That can be done to the double cardan joint. On my front SAS to my 01 Taco I just have normal u-joints on both ends.
My front driveshaft was a mix and match see this
https://www.yotatech.com/forums/f152...l#post52279771
Old 09-17-2018, 09:02 PM
  #30
zytra's Avatar
Very clean, did you ever have any concern of running short of travel on front spline?
I could keep my front U-joint (or C/V since I will install a dual case) and clearance it. If I get the 10" spline kit, I believe it comes with a U-joint, the specs don't say what's the max angle on them.
Old 09-19-2018, 07:01 AM
  #31
jakey poo's Avatar
What an understatement! I love watching your work ZUK! You've got that science down to an art for sure!
The following users liked this post:
ZUK (09-19-2018)
Old 09-27-2018, 10:42 AM
  #32
zytra's Avatar
We finished cleaning up the axle, knuckles and hubs yesterday. Cut off some brackets off the axle and gave it a fresh coat of primer.
Installed new bearing racers in the hubs. We should have the axle fully rebuilt next time we work on it.
Waiting on the front hanger, and new cases/crossmember
Old 10-06-2018, 10:02 PM
  #33
zytra's Avatar
Axle primed, working on the passenger side trunnion bearing preload.
Old 10-08-2018, 11:48 AM
  #34
zytra's Avatar
Next I will swap the spline and gear in the rear box.
Locked' Diff, crawler box and top shift rear case
Old 11-05-2018, 08:18 AM
  #35
zytra's Avatar
We installed the diff, finished rebuilding knuckles, adjusted preload and installed the new 30 spline Longfield front axles.
Getting new wheel studs next, and rebuilding the hubs and then we'll start tearing the IFS stuff.
Old 11-21-2018, 02:47 PM
  #36
rattlewagon's Avatar
Axle looks good! Keep at it!
Old 12-28-2018, 02:29 PM
  #37
zytra's Avatar
We installed the hubs and locking hubs, at least one of them because the other one was missing both the spring and the detente ball.
Next we'll start taking the IFS off the truck.
Old 04-16-2019, 07:35 PM
  #38
zytra's Avatar
We pulled the truck in the garage since it will probably take a while before we finish, and we took the IFS out.,
Everything came apart nicely outside of the passenger side torsion bar. The bolt was really hard to remove and it snapped on us when using a longer lever arm (probably 5ft). The other side came out really easy.
I'll try to sell the front diff with 529's and try to get rid of some other stuff now.
Old 05-01-2019, 08:00 AM
  #39
zytra's Avatar
Old 05-08-2019, 08:10 AM
  #40
zytra's Avatar
We're finally starting to put things on the truck.
Cutting the holes for the shackles was challenging as my frame had internal braces.
Other than that everything else went pretty well.
quick question on the U bolt. My axle is an 84 and based on the instructions I was expected to use 2 square U bolt on the passenger side (even though the manual says driver side), and 2 round ones on the driver side.
We ended up putting 2 round ones on the driver side and 1 square/1 round on the passenger side.
We'll continue in a couple of weeks
Quick Reply: Zytra's 90' Pickup 4x4 3.0
