Lumpy's no cut Zuk Mod
7 Attachment(s)
Alrighy, after too much hauling and tired of sagging I have finally decided on the Zuk Mod...I have read through 92Toys thread, Zuk's thread, Junkers88 and many more I have finally decided on the 5"x13"x150lbs Black Magic springs from Southwest Speed.
I do want a little lift and the new shoes from Treadwright are around 33x10 I think the 13" will give a nice look and ride, I went with the 150lbs because I do haul quite a bit but still need a comfortable ride for a 70 mile commute. So this is where she sits now, mind you I do have the el-cheap-o 1/2 leaf helpers from Advanced auto on there as well, made the ride stiff as hell but it was a quick fix for the time being. As she sits now. Attachment 164649 Attachment 164650 Attachment 164651 Attachment 164652 Right now I have about 21 1/4 from center to arch (what's left of it) Attachment 164653 From fame to leaf pack is roughly 8 1/2 could be a little less, it's not sitting level but close. Attachment 164654 Just under 3 between the bumps. Don't mind the twisted hanger in the background, it's just holding the broken leaf in place.... Attachment 164655 This weekend they'll go in, I don't have the time to do it in the evenings...Yes I know it doesn't take that long. |
A blast from the past...
Excited to see how it turns out... |
that's some awesome rust man.
Good job
12 Attachment(s)
And so it begun!!!
Took just over an hour or so to do. I rented a spring compressor to help me out. Attachment 164460 In order to get these in I had to remove the shock, I chose the lower they broke loose quite easily. So I jacked up the truck from the side of the hitch as far as it would go then I used a Toyota bottle jack at the front of the axle to spread it a little further. I was not able to get the spring compressed enough so I got it in place around the lower mount and used a heavy ratchet strap. With the spring top facing rear, I ran on end under the front of the axle and to the top of the spring on the inside of the upper mount and the ratchet side to the outside of the spring. As I cranked the strap it further compressed the spring and pulled the top forward. Then with a tap I ended up like this!!! Attachment 164461 Attachment 164462 I started by not removing the shock and left the tire on. I was hoping to do it from underneath...Well that didn't go well. Save yourself some aggravation and just remove 1 shock mount and the tire it will go much smoother. The first on took about 45 minutes or so the 2nd 20 min tops. Attachment 164463 Attachment 164464 Now this is before...around 8.5" Attachment 164465 And after...around 11.5" Attachment 164466 Before...almost 21.5" to the center. Attachment 164467 After... around 24.5 Attachment 164468 Before... Attachment 164469 After... Attachment 164463 Yes I know it's a lil dark...I'll get a better tomorrow. Attachment 164471 Now I know they will settle a little more probably about 1/2" I'm guessing. As for the ride it's much better, still rides like a truck but it's not going to knock out your fillings on a lil bump. From what I have read and just installing these tonight. If you are looking for just over stock and a better ride. 11" at 100lbs Lift and smooth ride 13" at 100lbs Stock and hauling 11" at 150lbs Slight lift and hauling 13" at 150lbs Probably getting a load or two of wood tomorrow so I'll know how much it settles and how the ride is loaded. |
cool been doing this mod now for ~ 20 years .. just did this to a 89 4Runner last week .. another happy customer :)
got a fix for your rusty sides as well .. you know the drill . |
1 Attachment(s)
Yes, I know...I'm right on the steel buckle of the rust belt!
Day time!!! After Attachment 164426 Before [IMG]https://i714.photobucket.com/albums/...ps2a0aff56.jpg[/IMG] |
Nice!!!
nice........!!!!!!
sweet build, im wondering were you able to run the 13" zuk mod springs with stock rear shocks or did you get longer travel? thanks in advance
Hmmmm. Makes me think I can just zuk my rear and get new springs for the front. Looks good.
