kelly1450's 86 4x4 chase truck
#26
You have to move the front hangers forward like 5 inches, I moved the rear about 2 inches but it may not even be necessary if a longer shackle is used
The reason I chose this setup is the front mounts dont hang low like the chevy springs even though they are longer than factory toyota springs by quite a bit and the explorers are spring under from the factory so they come with a nice amount of arch. Over the past few years I have been quite pleased with the explorer springs and would definitely do them again.
#27
Sweet ride! My goal is the same as yours, an all around capable rig. I just bought an elocker, need to get it installed. I will have to look into the explorer springs! sounds like a great alternative.
#29
Since I kept on breaking fiberglass camper shells I decided to build my own camper shell from scratch and then tested it on the Rubicom and the Mojave road, it works great, details can be found in link below.
http://www.expeditionportal.com/foru...g-camper-shell
#30
I just noticed that on the pic above if you look in the truck you can see me struggling with the steering wheel, doing the Rubicon in a day without power steering will sure tire you out! I do still prefer manual steering though.
Also, thanks for all the complements, the truck has come a long way
here's another from the Rubicon
Mahogany
08-12-2019 01:31 PM
Dharris1986
28
04-17-2017 03:34 PM
