JDM4X4's 1987 Toyota 4Runner SR5 Build
So I just bought an '87 4runner 2 weeks ago and it's completely stock...for now. I use to have an '85 Pickup with a 5 inch lift on 34's and a weber carb, but I didn't build any of it I bought it like that. I'm really looking forward to this build it'll be the first time I've done this much work to a truck. I'll get pictures and a rough plan up as soon as I can.
First goal is to get it to pass emissions first. It's failed twice...keeping my fingers crossed for round 3.
post pics :D
What have you done to help pass smog? Where are you failing?
It was like .5 grams per mile over the limit for NOX. I changed the spark plugs and wires after the first time, then if failed again. Now I have adjusted the timing, replaced the air filter, fuel filter and a couple of the vacuum lines. It is running a lot better now, I just haven't had time to get it tested again (I'm going on Tuesday). I also ran a compression test just to make sure i wasn't crazy uneven, it's a little low but it's pretty even.
How is the cat?
Triple check vacuum lines using fsm. I failed multiple times before figjring out my lines were messed up on egr system. Also check egr to ensure it is clean. Good luck |
i'll double check vacuum lines, cat is welded in so i didn't want to take it off yet.
Welded...yikes.
When I failed twice, I had replaced: - Cat - plugs - cap/rotor - wires - cleaned air filter - timing adjust - cleaned EGR - Replaces O2 sensor After all that I was still failing. Looked at the FSM diagram for vacuum hoses and noticed I had hooked some up wrong when I last adjusted something - fixed and passed with flying colors. Also, just check for vacuum leaks - you could have a leaky vacuum hose. spray wd40 around the hoses (gently) while idling...if idle rises when you do, that hose likely has a leak. |
I'm planning on replacing the exhaust anyway. Thanks Phil I totally forgot about the wd40 trick. By the way where else can I find the FSM, I tried the link from the thread with all of them and it didn't work.
Try right clicking and saving this file - that's how I got mine (this is for an 88 but should be fine for you):
http://web.archive.org/web/201011261...4runner_88.pdf If that doesn't work, go to the source and right click on the same link: http://web.archive.org/web/201011261...fsm/index.html |
Thanks
http://i1355.photobucket.com/albums/...ps86fdb29c.jpg
Here's a photo I would have taken more today but things got a little crazy. Goals for the near future: Pass emissions (#1 priority, it's getting tested tomorrow) Stop as much of the leaking as possible Adjust valves Replace exhaust/intake Replace front coil springs, leaf springs and shocks Tires Clean the body up a little bit And any other little things she throws at me Long Term build motor for supercharger on the side (10lbs) re-gear diffs to 4.56 bumpers and sliders rear disc brake conversion Rims and tires possibly with spacers to get a wider stance. soft top interior (more details later) marine grade sound system transmission/t-case? finishing touches on body (i.e. little to no rust, minimal dents/scratches and mostly even paint) it's gonna take some time, and money, and it will probably change at least 3 times, but that is the plan for now. |
.43 grams per mile over....stupid emissions. However, I have decided to start getting the parts to swap my battery and intake locations.
Looks good. What kind of radiator is in there? I've never seen one like that in a first gen 4Runner before.
PO replaced it. I think its just an oem one.
sorry i haven't updated you guys in a couple of days, so i have all new vacuum lines, i adjusted the valves and i'll be changing the cat and egr valve soon. I am however debating on a rebuild...Thoughts? concerns, things to look out for?
by the way no more supercharger in the long term plans...told you it would change.
so the biggest hurdle right now is funding i have...so give me a minute and i might have some, lol.
