nvwiggins 85 5.0 T4R HO
Old 10-19-2017, 08:57 PM
  #181
nvwiggins's Avatar
Originally Posted by palmetto
Not sure if you're happy about this swap or bored waiting for more progress. Truth is it's been a busy summer. Finally worked on the front cross member today and have more welding to do on that. Met the guys at Desolate Motorsports that specialize in TTB Bronco suspension and got some axle truss, uniball conversion and radius arm parts from them which should make a few things on the build much easier. Ummm so I guess I'll post a picture but it's not much progress just one fully boxed/welded section of the crossmember and the other section being welded.
Old 10-19-2017, 10:11 PM
  #182
84 yota dude's Avatar
Nice welds
Old 10-19-2017, 10:31 PM
  #183
nvwiggins's Avatar
Thanks! It's hard to stay consistent though, especially after too much coffee and not enough food haha! Been working on getting the welder dialed in and comfortable positions but that can be tricky with all the curves and everything involved with these crossmembers. But it should be beefy enough when it's done!
Originally Posted by 84 yota dude
Nice welds
Old 10-21-2017, 04:05 PM
  #184
Haha I get that, definitely looks beefy!
Old 10-23-2017, 07:21 PM
  #185
nvwiggins's Avatar
Got both of the crossmembers fully welded and mocked in place to check clearances. Bump vs droop
Crossmembers that will get joined with tubing in the open holes you can see.
Ride height vs bump
Old 10-23-2017, 08:42 PM
  #186
Scweet. What's the plan for the rear?
Old 10-24-2017, 09:22 AM
  #187
palmetto's Avatar
The more i look at this the more i like it. Also OP you need to find me one of those T5 to Toyota case adapters or at least get me the part number off of it. Im really wanting to put a 2.3 turbo and a T5 in my 85.
Old 10-24-2017, 01:02 PM
  #188
nvwiggins's Avatar
I plan on running a Ford 9” with spring under Deaver springs with King bypasses. Front and rear will have selectable lockers.
So the adapter was made by advanced adapters in the 90’s, but they have long since discontinued that option.
Old 10-24-2017, 01:09 PM
  #189
That sounds awesome
Old 10-24-2017, 07:01 PM
  #190
nvwiggins's Avatar
That sounds awesome
Man I hope it turns out as awesome as it is in my head haha. It’ll have dual cases as well. I have to cut the rear wheel well out quite a bit, and I’ll be mounting modified bedsides that will match the front.
Old 10-24-2017, 09:15 PM
  #191
nvwiggins's Avatar
Few more from today, put in a complete axle to make sure that the ujoint that allows the axle to pivot in the center doesn’t bind throughout full cycle of the suspension then I tied the crossmembers together with tubing. Also swapped in Rigid LED headlights instead of the VisionX 4x6s I had adapted to fit. I think they look much better.
Bump
Droop
Front side
Backside
Old 10-26-2017, 09:08 AM
  #192
Sounds like an awesome rig when all done!
Old 12-26-2017, 01:01 PM
  #193
nvwiggins's Avatar
Cut the inner fenders out to fit some little shocks in there. After New Years I should be hitting it pretty hard, hope to make some good progress.
Old 12-27-2017, 09:32 PM
  #194
rustED's Avatar
Wow, you've been busy too! Making some awesome progress on the front suspension, man that thing is going to have some crazy amount of wheel travel!!!
Old 03-19-2018, 07:08 AM
  #195
nvwiggins's Avatar
I decided that I wanted a lower ride height so I redesigned the front suspension crossmember. I also ordered a custom made set of deaver leaf spring for the rear end so now I’m waiting for those. I mocked up the new front crossmember the other day and am really liking the ride height a lot more although there is a little more fab work involved to make it all fit. Here are some more pictures for now.
Old 03-19-2018, 02:17 PM
  #196
Looks mean
Old 04-05-2018, 07:37 PM
  #197
RASALIBRE's Avatar
Really dig what you're doing here. How do you plan on mounting those rear quarters, what brand are they?
Old 04-13-2018, 07:00 PM
  #198
nvwiggins's Avatar
They’ll be mounted on tabs off of the body and some directly into the body. They are Hanneman bedsides made for a truck that I’ve trimmed to fit the 4runner body.
Old 12-03-2020, 03:37 PM
  #199
Ethan Elmer's Avatar
Originally Posted by rustED
Welcome to YotaTech, Nice build! I think that's cool too that you got your dads motor back! I wish mine was a fuel injected HO motor. I'm interested in the T5 trans and adapter, does the trans crossmember bolt up in the stock location or do you use a custom crossmember? What kind of radiator are you currently running? Does it have enough clearance with your core support? Just curious, I just got a new aluminum radiator, fan shroud , and 14" electric fan from CFR performance, but will probably end up removing and rebuilding the entire core support around the new radiator.I will be keeping the grill in the stock location, but will probably have to run hood pins unless I can find a way of retaining the factory hood latch mechanism.
Cool build, its nice to see another 302 build thread! Id like to learn more about the T5 trans an adapter as a possible option down the road if my setup doesn't work out. Im running NWOR bellhousing and a toyota G52 or G54 tranny, but am lookng to upgrade to a W56 hopefully by next summer. Anyway, look forward to seeing your progress!
I just purchased a 1994 4runner and Im going to do the ford 302 swap. Ive heard a lot of “promising” things on this build haha, but I am determined to make it happen and do it well! The old motor is a 4wd SR5 3.0 v6 and the manual tranny that is from is it supposedly still good, but I also have a new one for the 302, not sure which route is best with the tranny. I would like to avoid cutting firewall and core support as much as possible. Also keep the old gauges working. The new engine is carbureted and I would like to avoid as much electrical as I can, but id like to keep the AC if I can. I understand the price of all this and the struggle of all this and I love it... cant wait! I want to be driving this thing down the road in the near future! I need major help! ANYTHING HELPS! Please educate me! Also really trying to avoid NWOR. Not thrilled with them.
THANK YOU!
weseterly74
05-22-2017 01:20 PM
tmarsh38
10-22-2014 06:50 PM
runs-on-4
06-02-2013 10:17 AM
Trail Blazer
22
02-05-2013 07:51 AM
yotacruzer93
Domestic Swaps
28
11-15-2012 06:00 AM
Quick Reply: nvwiggins 85 5.0 T4R HO
